Configure egress port-based shaping to bind the maximum rate at
which traffic leaves the port.
- In the Device Physical
View tab, select a port.
                In the navigation pane, expand
                Select General.
                Select the Interface
                    tab.
- From EgressRateLimitState, select enable.
                In EgressRateLimit,
                    type an egress rate limit in kilobits per second (Kb/s).
                Select Apply.
